LS Engines and Pushing Water
So I am sitting here trying to figure out WHY LS engines push water. There are SO many other engines out there with the same head bolt design (10 bolts per cylinder head.) I am just confused as to why the LS engines have the problem with pushing water and you never hear of any other engine out there doing it as commonly as these engines...
Maybe it has been answered before but it seems like everyone has there own opinion. Yeah, you can run less timing and have a good tune and "supposedly" you shouldn't have any other issues. Then there are the people that say it's the cylinder walls going out of round. And last there are the ones that say it doesn't matter how good your tune is, or how much boost you're running, once you hit around 1200 flywheel hp it's going to start lifting.
The reason I am so curious about this is because I didn't opt to go with a LSx engine yet. But my engine now is an iron 370, O-ringed, 1/2" head studs, ETP heads (thicker deck,) and copper head gaskets... I am just really starting to wonder how far I'm going to be able to push my S91.
Yeah i would have to agree. I pushed my stock buick v6 to 32psi, stock graphite gaskets and everything, never touched. Just lock the wastegate shut and max out the turbo. that is a 4-bolt head as well. Did that for a whole year and never pushed a drop. In fact i broke a piston from some knock and still didnt blow the gasket. I know with the bigger bores it is obviously going to push easier, but can it really be that big of a difference?
