6.0 iron block to L92 aluminum ???s
Old 12-15-2008, 07:58 PM
LSXS10's Avatar
Default 6.0 iron block to L92 aluminum ???s
Hey guys ive got a few quick ???s When going from a 6.0 iron block to a 6.2 block what all is different? do these blocks have a provision for an older cam sensor? I know the valley cover is different but what else? Thanks....
Old 12-15-2008, 08:31 PM
Restricted User
2001 Pewter WS6's Avatar
Valley cover is different, need a different timing chain cover, harness extension for the new cam position sensor, need new lifter guides, knock sensors get relocated to the sides of the block so you need and new harness for that. I think that is about it...
Old 12-15-2008, 09:44 PM
LSXS10's Avatar
So... if im running a front mount dizzy kit i just need the valley cover and thats it??
Old 12-26-2008, 04:13 PM
TJ
TJ's Avatar
that should be it.
if you have the dist setup, youve got everything else.
Quick Reply: 6.0 iron block to L92 aluminum ???s
