Cam with no tune??
Old 12-22-2008, 09:29 PM
JB_97ws6TA's Avatar
Default Cam with no tune??
I was just wondering if I can start my car after the cam install with the rear o2's unplugged and stock programming. I only want to do this so I can heat cycle to retorque everything and make sure all is well before I get it tuned. I was also curious if you can pass emissions with the rear o2 sensors tuned out?
Old 12-22-2008, 09:32 PM
95mysticta's Avatar
depends how agressive the cam is... any mild cam will run and drive no problem its when you start getting into the wild cams that will have a hard time running on a stock tune.
Old 12-22-2008, 09:46 PM
JB_97ws6TA's Avatar
Oh I guess that would be helpful it is basically lunati's hotcam I think it is 219/228 @.050
Old 12-22-2008, 09:48 PM
Chace02ws6's Avatar
you will be fine 228/228 and i drove it around. I wouldn't rev or run it about 3k rpm's
