LS2 Serpentinebelt setup with ProCharger ?
Hello,
we are currently building an LS2 engine with a serpentine belt kit from Vintage Air. Now my question is - is it still possible to mount and run a ProCharger Kit on the LS2?
Thanks you very much for your ideas.
The ProCharger GTO system uses a crank pulley that bolts to the outside of an aftermarket harmonic balancer. If your Vintage Air system runs off the stock balancer, than swapping the balancer out to one made by Fluidampr, pn#740102 will then allow the ProCharger crank pulley to bolt up. Bob
