question about what mass air to use with 92/92 fast
Old 12-28-2008, 11:56 PM
bigfatls6's Avatar
Default question about what mass air to use with 92/92 fast
I will be installing a fast 92/92 setup with my heads and cam on my 2002 ss camaro. I would like to upgrade the mass air meter along with the lid to take full advantage of the fast 92/92. what 85 mm mass air will work? I will be getting a dyno tune at the same time. could I use a slp 85 mm mass air for the 98-00 camaro and trans ams since I am getting the car tuned or will it still have problems? What other choices are there when it comes to 85 mm mass air meters? I have heard the zo6 mass air is also a good one to use. will all of them work fine since I am getting the car tuned? Or will it be hard to tune the car with certain ones?
Old 12-29-2008, 12:07 AM
405HP_Z06's Avatar
Your best bet is the Z06 85mm or the Powrmax 100mm. Don't use one of the 'modified' after market air meters.
Old 12-29-2008, 12:09 AM
bigfatls6's Avatar
Is it hard to tune the car with the powrmax 100mm? I will be haveing it dyno tuned once every thing is installed and I plan on installing every thing at once.
Old 12-29-2008, 12:13 AM
405HP_Z06's Avatar
Nope, Bruce provides tables to start with. Any competent tuner can tune with this MAF. It uses the LS7 MAF element with a custom housing.
Old 12-29-2008, 12:18 AM
bigfatls6's Avatar
Would it be worth using this on a h/c/i stock bottom end ls1? I am using the prc stage 2.5 5.3 heads and a 230/230 598/612 111+2 cam with a fast 92/92. I have been going back and forth debating if I should swap from the stock mass air and my regular slp lid. I don't want those to hender the rest of the set up from reaching its potetial. It just make since that if you use a 92mm intake the stock 75mm mass air and regular slp lid will choke down the flow right?
Old 12-29-2008, 11:50 AM
LS199's Avatar
I would go with slp 85,fast toys lid also 85
Old 12-29-2008, 01:00 PM
Banned Village Idiot
LS1BLKSS's Avatar
get the z06 MAF 85MM its pretty damn cheap i got mine for like $35 on egay
Old 12-29-2008, 01:46 PM
slobird's Avatar
I have the Z06 MAF and the FAST TOYS 85mm lid, very pleased with the setup. I couldn't see running the stock MAF with the Fast 92 and choking it down.
Old 12-29-2008, 02:04 PM
SS1875's Avatar
ZO6 85mm, or you could run this. http://www.texas-speed.com/shop/item...d=914&catid=75
Old 12-29-2008, 02:39 PM
SidewayzOZ's Avatar
I went with the FT lid and SLP MAF with my 92 setup, it fits together nicely.
Old 12-29-2008, 02:46 PM
streetassasin's Avatar
why not go speed density?
Old 12-29-2008, 03:18 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We stock the TSP 100mm maf & the 100mm lids will be ready next week!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 12-29-2008, 11:03 PM
SidewayzOZ's Avatar
Grrr....I gave up waiting on the lid Can't wait to see it!
Old 12-30-2008, 08:22 AM
chrs1313's Avatar
mmm sounds promising...are going to run back to back vs a 85mm lid/maf setup
Old 12-30-2008, 10:19 AM
black01_WS6's Avatar
the 100mm lids/maf combo would be nice to actually see. Some dyno numbers comparing the two would be nice as well.
Old 01-01-2009, 06:23 PM
Super Speed's Avatar
x2 for speed density
Old 01-02-2009, 04:47 PM
'02 WS6's Avatar
x2
Especially since I am in the process of upgrading fuel system, intake, MAF, and lid so that combo would be good!
Only cars I've seen w/ the 100mm MAF are the 4.000+ bore cars, so will they even be beneficial on a stock bore/bottom end ls1? If so, count me in.
Old 01-02-2009, 06:28 PM
caviness's Avatar
to the op get what your tuner likes to tune,me personally im going with z06 latter
Old 01-03-2009, 09:34 AM
01Z0H6's Avatar
Another one for Z06 MAF... Like some of the others, i got a new one off of Ebay for $65.00 shipped.. Got the 85mm lid as well, along with the FAST 90.
stay away from the SLP MAF! way overpriced imo, and you are paying for the name! Everyone i have "personally" spoke with have pitched the SLP MAF and changed to the Delphi 85 mm (Z06).. Why wouldn't you?
GL...
Old 01-03-2009, 10:02 AM
Mike454SS's Avatar
X3...ditch the MAF altogether, and spend the money on a good tune.
Quick Reply: question about what mass air to use with 92/92 fast
