Tire question
Tire question
I have a 6 yr. old set of Michelin tires with 9k miles on my car. The rear's are cooked the fronts don't look to bad..rubber has hardened alittle. I'm going to put Nitto 555 dr's on the back, should the fronts be changed??? I guess the question is.... is there any ill effects to running different tires with different compounds or do i just put the 555ep's on the front for safety reasons.
Good point... i guess i'm really up in the air on what tire to buy I don't drag the car, only used on nice days...but want somthing that will hook well on the street. Maybe i should look at the best tire i can get that will hook reasonably well and good cornering characteristics, any thoughts?
