Pulled Vally Cover...What are these two holes?
I pulled my vally cover tonight while everything is apart, because I'm cleaning everything up, and noticed these two holes, they are filled to the top with oil and a thick like gunk, and I just wondered what they were for, where they go, and or if I should clean them out?
LSX Mechanic
Those two holes bottom out about 1 1/2 inches down. They serve no purpose.
I'm assuming you're grinding that tab for the LS6 valley conversion. Doing it with a dremel is going to take you forever. If you don't have access to an air compressor I would go get a metal file bit from Home Depot or something and use it on a drill. It will take that tab out a lot quicker.
Even with a 20,000 rpm die grinder, it takes me about 20 min to clear that tab enough for the LS6 valley to fit. FWIW.
