vindicator cam, and clearance....
as from my understandings, the vindicator would be a fantastic choice for the daily driver in a ls1, and i also understand that you can run the prc stage 1 heads without n e problems, but someone told me that the cam was so big that there wasnt enuff clearence to be safe, he said that if the car was at a high rev and you went to shift from second to 3rd and ur rpms hadent dropped and u just so happened to miss the gear and get back on ur rpms, that ur subject to espacially bend a rod.... but im just not very famialiar with this big of a cam so if u could give me some info, so i could go ahead with the install or consider something else... thanks
A buddy of mine has the vindicator in his trans am and daily drives it and from what i hear fits perfrectly fine with stock heads but im not sure about other heads. Id pm ron @ vengeance about the clearnace cause im sure he knows
That cam is 240/244 IIRC so yes any cam over 230* it is always wise to degree ity and check PTVC>
