2008 Impala SS Engine/Transmission questions
Gentlemen,
I am interested in increasing the performance of my Impala but not at the expense of destroying my transmission and 5 year/100K powertrain warranty simultaneously. By the sound of things on this forum, the transmission I have is already pretty much being stressed to the max with a 303 hp powerplant. Is this a fair assumption to make, and, if not, where should I start with non-warranty threatening performance modifications???????The transmission?
Thanks in advance for any input!
EJL1970:
EJL1970:
Ok. So, if I put on a CAI and exhaust without the shift kit, can I expect a long and happy life from my transmission??????........minus a large number of burnouts of course?
when i picked up my car it had 14k on it. At 15 the tranny **** out. the guy i bought it from was 62 so i dont think he was beating the snot outta it. The trannys are just crappy anyways. They have been a problem in all the previous years anyways. They just dont make a strong enough tranny for the power they are supposed to handle.
FYI... The dealership can check the ECM/TCM for any re-programs. When a program is uploaded to a module there is an authorization code supplied by GM when new software is downloaded. If there is history of a programming update using the same auth code it automatically voids the warranty. Also, you can go back and look at previous data and if torque/HP numbers are higher than possible on a stock vehicle they can detect there were performance upgrades done. Best way around it is to buy a new ECM/TCM when you buy the vehicle, program it and save the original for when it has to go back to the dealer.
I'm just saying if you had a major repair, such as engine or trans, they will most likely check and you will be stuck with the large bill.
Tap Dat, are you saying that if you use a Preditor tuner with performance tune, and when you take your car in to the dealer even with the stock tune reinstalled, the dealer will be able to tell if you had a custom tune installed, and then can yank your warranty?
