who sells the 3 to 5 wire adpter harness for a zo6 mass air?
I just bought the z06 mass air that is a 5 wire mass air and I need the adapter harness to use it on my 2002 camaro ss. who sells the adapter harness?
well there is a question you need to ask yourself first...
1) Assuming you have a Fast Toys 85mm lid to compliment your 85mm MAF, did you drill a hole for your IAT sensor in your lid?
B/C there are 2 harness that can work. One can be to bypass you IAT b/c you have it in your lid so you have your stock sensor already hooked up to it. The other being that you did not drill the hole in your lid, thus leaving you IAT sensor all alone.
So which methiod you using?
LS1Tech Premium Sponsor
We stock the adapter. Give us a call and we can get it shipped out today!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
