who sells the 3 to 5 wire adpter harness for a zo6 mass air?
Old 01-06-2009, 08:52 PM
bigfatls6's Avatar
Default who sells the 3 to 5 wire adpter harness for a zo6 mass air?
I just bought the z06 mass air that is a 5 wire mass air and I need the adapter harness to use it on my 2002 camaro ss. who sells the adapter harness?
Old 01-06-2009, 09:03 PM
drain89's Avatar
Fast Toys Performance or WS6store.com
Old 01-06-2009, 09:51 PM
TORCHD 02 TA's Avatar
well there is a question you need to ask yourself first...
1) Assuming you have a Fast Toys 85mm lid to compliment your 85mm MAF, did you drill a hole for your IAT sensor in your lid?
B/C there are 2 harness that can work. One can be to bypass you IAT b/c you have it in your lid so you have your stock sensor already hooked up to it. The other being that you did not drill the hole in your lid, thus leaving you IAT sensor all alone.
So which methiod you using?
Old 01-07-2009, 08:36 AM
bigfatls6's Avatar
I have a texas speed 85mm lid but it already has the hole in it. It really doesn't matter because I can put a filler in the hole.
Old 01-07-2009, 09:18 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
We stock the adapter. Give us a call and we can get it shipped out today!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
