L92 with LS2 cam swap???
I have a L92 motors & I'm swapping for a 3 bolts cams. I have order the lingenfelter conversion kits (cam sprocket, bolt & black tensioner).
I install it but the chain is really loose, i can move the cam sprocket about some degre on both side????
Does someone know if it's normal or I keep the L92 tensionner???
Thanks!
Kevin..
Thanks!
Kevin..
Ok with the LS2/LS3 black tensionner, I have 1/4 inch loose on each side on cam gear. I reinstall the L92 tensionner with the LS2 cam gears & everything is ok!
So I can keep it like this??
Kevin..
Kevin..
