4L60 speedo calibration help plz
Old 01-08-2009, 11:09 AM
BigZee71's Avatar
Default 4L60 speedo calibration help plz
Ihave a 93 Z28 that I just insalled 3.73's in over 2.73's.
Did my trans come with a 17 (RED) tooth drive gear? or a 15?
Do I need a 43 tooth Driven gear?
are 245/50/16 tires 26" tall?
Old 01-08-2009, 11:57 AM
Closed ex-Sponsor Account
tptransmission's Avatar
Not sure of what you have in there but you need a 15 drive with a 45 driven. 25.1" tall tire
Old 01-08-2009, 12:40 PM
$O$OE's Avatar
is there any benefit having the 4l60 from the 4160E??? Just curious on the advantages and disadvantages of them both?
Old 01-08-2009, 12:56 PM
BigZee71's Avatar
http://www.transmissioncenter.net/sp...n_______va.htm
The chart on this web page tells me I need a 43 tooth driven gear with 15 tooth drive.
I got 786.58 revolutions per mile
25.64 tire hight
so..
(15 X 3.73 X 786.58) divided by 1001 = 43.97 (44)
If I use your tire height, I get 44.9x (45)
Would you know what drive gear my car came with from the factory?
Old 01-08-2009, 12:59 PM
BigZee71's Avatar
4l60 uses a "tv" cable to adjust shift, E uses the computer and solinoids
4l60 uses drive and driven gears to calibrate the speedo, the E uses a computer programer.
Old 01-08-2009, 01:13 PM
$O$OE's Avatar
and the advantages or disadvantages of them both? or same **** if some1 has a 4l60 or a 4l60E..ones electric and ones not....thats why on 95+come with the electric, not sure thought if so please correct me
Old 01-08-2009, 01:20 PM
It depends on how you build it. Internally the parts are interchangeable for the most parts. The later desing 4l65e and 4l70e have 300 mm converters, longer statror support and turbine shaft. But you can get the 4l60 fairly close to holding the same levels of power as an 4l60e just takes money.
Quick Reply: 4L60 speedo calibration help plz
