4L60 speedo calibration help plz
Ihave a 93 Z28 that I just insalled 3.73's in over 2.73's.
Did my trans come with a 17 (RED) tooth drive gear? or a 15?
Do I need a 43 tooth Driven gear?
are 245/50/16 tires 26" tall?
http://www.transmissioncenter.net/sp...n_______va.htm
The chart on this web page tells me I need a 43 tooth driven gear with 15 tooth drive.
I got 786.58 revolutions per mile
25.64 tire hight
so..
(15 X 3.73 X 786.58) divided by 1001 = 43.97 (44)
If I use your tire height, I get 44.9x (45)
Would you know what drive gear my car came with from the factory?
25.64 tire hight
so..
and the advantages or disadvantages of them both? or same **** if some1 has a 4l60 or a 4l60E..ones electric and ones not....thats why on 95+come with the electric, not sure thought if so please correct me
Closed ex-Sponsor Account
It depends on how you build it. Internally the parts are interchangeable for the most parts. The later desing 4l65e and 4l70e have 300 mm converters, longer statror support and turbine shaft. But you can get the 4l60 fairly close to holding the same levels of power as an 4l60e just takes money.
