injectors
Old 01-08-2009, 03:41 PM
trav00ws6's Avatar
Default injectors
i will probably need some injectors after my head cam swap.
magic stick 4 cam with a set of 243 heads. and some basic bolt ons
Old 01-08-2009, 03:47 PM
trav00ws6's Avatar
oh duh i forgot my nitrous kit... but a have not used it yet lol
Old 01-08-2009, 06:32 PM
purdueranger's Avatar
wet kit - ford SVO30#s
dry kit - ford 42# injectors
Old 01-08-2009, 06:40 PM
XtraCajunSS's Avatar
If you are using a wet kit, these will work:
135-INJ-621037-8 Delphi/Lucas 37# High Impedence Fuel Injectors
-Static Flow Rate: 37.27 lb/hr @ 43.5PSI
-Static Flow Rate: 43.04 lb/hr @ 58.0PSI
-Dynamic Flow Rate: 8.42 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 43.5PSI
-Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
$332.99
For a dry kit, use these:
135-INJ-621031-8 Delphi/Lucas 42# High Impedence Fuel Injectors
-Static Flow Rate: 42.29 lb/hr @ 43.5PSI
-Static Flow Rate: 48.83 lb/hr @ 58.0PSI
-Dynamic Flow Rate: 9.96 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 43.5PSI
$332.99
http://www.thunderracing.com/catalog...vid=3&pcid=163
Let me know if you need any help or tech advice...
Thanks,
Shane
Old 01-08-2009, 07:58 PM
jomomma's Avatar
go with 42`s. gives you room for future upgrades.
