help me pic a cam!! vindicator or ms4
Old Jan 8, 2009 | 11:05 AM
johnster's Avatar
Default help me pic a cam!! vindicator or ms4
hey guys,, putting a set 0f 5.3s on mill 2 58cc with .040 gasket. i cant make up my mind on which cam 2 put in, i have the ms4 but 4 some reason i wont to put the vindicator in the car, i guess i wont the one that makes the most hp and tq
do yall think i should use 7.4 or 7.35 pushrod?
let me c some info
Old Jan 8, 2009 | 11:22 AM
trav00ws6's Avatar
going through the same problem...but i think the piston to valve clearance is already really close, so with the milled head your just getting closer... whats the factory head gasket thickness?
i thought i remember seeing a thread saying to use 7.25 push rod...
Old Jan 8, 2009 | 11:23 AM
AznMuscle's Avatar
You fly cut yet? There is no way those cams will fit a milled head like that, with that gasket. I'm assuming you mean .040 gasket right?
Old Jan 8, 2009 | 12:02 PM
98blueSScamaro's Avatar
for sure will need flycutting. but i made my numbers with stock ls6 long block cam only with the vindicator and i really like the cam. And the 58cc will really add some Torque with this cam
Rob
Old Jan 8, 2009 | 01:32 PM
johnster's Avatar
yes im going to flycut
Old Jan 8, 2009 | 01:48 PM
Johnnystock's Avatar
I know you need 7.4 for a MS4 cam...7.25 could be too short.
Old Jan 8, 2009 | 07:46 PM
03_SS_22's Avatar
let me c some info
get a custom tailored cam
would be your best bet
Old Jan 8, 2009 | 09:02 PM
SOMbitch's Avatar
You will need to measure for PR length but i bet it will for be shorter than 7.4 cause you are milled so much.
I would get somebody to spec you a custom cam BTW.
 Michael S. Palmer
