Did I pick the right cam.
I have a 2000 Trans-am Mods include. Ported heads 202 intake 157 exhaust. slp long tubes. Comp cam 224-228 563 lift on a 112 center. lid. all the free mods. turbo 400 with a larry wilson 3500 nitrous prep stall. 100 shot nitrous exp wet kit.
3340 race weight. 373 gears. best run to date. 11.70 at 116 with a 1.56 60ft, on motor. on the juice. 10.70 @ 126 with a 1.46 60ft.
I just bought a thunder 230 224 cam. Will I slow the car down?
Re: Did I pick the right cam.
Heads were done local. The car dynoed before the heads and cam. 330 328 tq. Right after I put in the comp cam and ported heads. 399 hp 389 tq on the motor 499 540 on the 100 shot. So I think the head porter did pretty good.
Come on guys, help a brother out. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ February 13, 2003, 07:32 AM: Message edited by: cruzerbobby01 ]</small>
I would have stuck with the cam you had prevously. I am not sure how much you'll gain on motor with this cam (4-5RWHP tops) Might not be worth the cost. On spray it will be a wash I think
Cheers,
Chris
Cheers,
Chris
LS1Tech Co-Founder
I like how your current cam is working, I'm not sure if you will pick up that much since you are already running what I consider to be one of the best big cams out there.
Ok. so let me ask you this. Is there a better cam I really want to pick the car up on motor.
I still have the old cam in.
I would think that the single pattern 228/228 cam from Comp would pick you up some performance N/A, and shouldn't noticeably hurt your N2O runs, in fact, it may even improve your N2O runs. I've always thought it was better to set your car up to run N/A then spray on top of that. Unless you're spraying some ungodly shot of the laughing gas, then you may benefit a little more by going with the split duration.
<small>[ February 14, 2003, 08:39 PM: Message edited by: RAGEman ]</small>
