turbo v6 camaro
turbo v6 camaro
what up guys,i was just wondering how hard it would be to piece together a turbo kit for my v6 camaro(3.4).i wanted to make it rear mount so i wouldnt need to buy an intercooler right away,plus i have a friend that works at a muffler who might be able to hook me up.1st is how much much can my motor take?if i do this i plan on only running around 5-7psi would that be safe? and also would 305 injector drop right in?any info will help.
^That, and try here: www.fullthrottlev6.com. There are plenty of people with turbo v6s there, Tiago and some of his projects among them. 3.4 is a little trickier, but there are some around.
i would drop an l67 in there (obviously not use the supercharger for clearance issues). and l67's can take quite allot of punishment if tuned properly. the motor loves boost.
building a turbo kit will not be cheap.
you have to buy a waste gate (if turbo does not have an internal one)
turbo
blow off
injectors
fuel pump
clutch ?
more...
and there could be more things that need to be done to the engine ( eg harder valve springs to prevent valve float under boost)
good luck
turbo
blow off
injectors
fuel pump
clutch ?
more...
good luck
