oil is going somewhere?????
Old 01-13-2009, 01:00 PM
proace4's Avatar
Default oil is going somewhere?????
so i have been checking my oil daily and i am losing oil. well i cant quite figure it out? i checked everything i could think of and finally gave up andtook it into a buddies shop. he had his "guru" go through and he found no leaks but that my PCV valve was stickin and that could result in my loss of oil. what do you guys think? i dont know much about the PCV valve or its jobs... but from what i gathered it helps with oil pressure to the top end? any thoughts owuld be appreciated! thanks in advance
Old 01-13-2009, 01:19 PM
ss.slp.ls1's Avatar
Yes, a bad PCV valve will allow oil to enter into your intake manifold and burn up.
Old 01-13-2009, 01:21 PM
proace4's Avatar
ok. so if i replace the PCV valve will that solve my problem or since its been leaking... do i have other problems?
Old 01-13-2009, 01:23 PM
ss.slp.ls1's Avatar
Replacing it will stop the oil from entering your intake manifold. You said you had no leaks. Next thing to do would be to perform a compression and leak down test to see if your piston rings and valve seals are still good.
Old 01-13-2009, 02:08 PM
proace4's Avatar
thanks!!!
Quick Reply: oil is going somewhere?????
