Got a pile that needs to come completete
Old 01-16-2009, 09:51 AM
boomtubes05's Avatar
Default Got a pile that needs to come completete
Well i need alittle help here i got a 6.0 lq4 short block complete w/15k, tea stg 1.5 5.3 heads,ms4 cam ,sharpe rockers ,double roller adj timing chain,and comp hydro lifters.
1.The question that i have is do i have to flycut the pistons and if so would i just be better of upgrading to a better piston with valve reliefs?
2.Will the stock lq4 heads gaskets work on this set up
Old 01-16-2009, 11:00 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
If those heads have larger than stock valves and/or any milling done to them, you will need valve reliefs. Flycutting isn't impossibly difficult with the engine out of your vehicle....but there's also added peace of mind and extra strength that comes from having an aftermarket forged piston in there. Do you have a machine shop near-by that you trust with balancing and machining your short-block?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 01-16-2009, 11:34 AM
Yea the heads have 2.020 intake and 1.57 exhaust valve and decked .010".Yeah Matt i also have a shop that i have do alot of my bbc work for my braket car. Im not to up on the lsx motors to much and the aftermarket parts that are availble.So what would u sugguest for a piston .Also would u have the cam card for that cam i bought it second hand?
Old 01-16-2009, 02:38 PM
bump !
Old 01-17-2009, 12:43 PM
anyone else have some input .Ill take as much as u got
Old 01-17-2009, 12:49 PM
99blancoSS's Avatar
Are you going to spray at all?
Old 01-17-2009, 12:50 PM
ya bout a 150 200 shot
Old 01-17-2009, 12:51 PM
i wanna built it right and safe
Old 01-17-2009, 01:04 PM
99blancoSS's Avatar
I'll pm you with a few idea's. Budget is a good thought as well, how much do you want to spend or not spend..LOL
