pushrod lift?
Old 01-17-2009, 08:27 PM
Green3spd's Avatar
Default pushrod lift?
How would u figure up lift if i went to a 7.200 to a 7.400??
Old 01-17-2009, 08:51 PM
96capricemgr's Avatar
Same formula you use to detemine displacement from longer connecting rods.
Old 01-17-2009, 10:35 PM
speed_demon24's Avatar
Old 01-18-2009, 12:53 AM
fergymoto's Avatar
LOL nice.
Just to clear that up, in other words increasing pushrod length does not have any effect on the amount of lift.
Old 01-18-2009, 07:33 AM
shbox's Avatar
Pushrod length is adjusted for correcting geometry, not for factoring lift.
Old 01-18-2009, 09:49 AM
RoAdRaGe912's Avatar
Old 01-18-2009, 10:08 AM
Elliott's94Z's Avatar
Exactly
Old 01-18-2009, 02:44 PM
Green3spd's Avatar
So....?
Old 01-18-2009, 02:49 PM
krill's Avatar
Originally Posted by fergymoto
LOL nice.
Like he said, the lift wont change.
Old 01-18-2009, 03:58 PM
blackz93's Avatar
But, geometry does affect lift. Albeit minimal.
Old 01-18-2009, 05:13 PM
fergymoto's Avatar
But when the geometry is right on every setup like it should be this doesn't even come into play
Old 01-18-2009, 09:28 PM
Green3spd's Avatar
ok.. then ill forget about it.. lol
Old 01-18-2009, 10:18 PM
Yeah just leave them alone unless you do heads/cam swap
Old 01-18-2009, 10:21 PM
Green3spd's Avatar
Well I did a cam swap..
Old 01-18-2009, 10:33 PM
JB_97ws6TA's Avatar
if you left the heads alone you should be fine with 7.2 if you had the heads milled or changed valves with a different height or went with a thinner heads gasket you will have to check your geometry
Old 01-18-2009, 10:56 PM
the_merv's Avatar
Yea if you have the Geometry off you will have problems. All you are doing with a longer/shorter Pushrod is changing the angle of the Rocker on the Valve. You are still moving it the same distance.
Old 01-18-2009, 11:12 PM
Green3spd's Avatar
Thanks.. thats exactly the defintion I needed..
Old 01-19-2009, 09:42 AM
blackz93's Avatar
True. And it's seldom right.
Old 01-19-2009, 10:00 AM
fergymoto's Avatar
Yeah, unfortunately.
Old 01-19-2009, 11:40 AM
ss.slp.ls1's Avatar
Glad you got your answer. And to add to it, if you increased your rocker arm ratio (using 1.6 or 1.7 rockers) then your lift will increase.
Quick Reply: pushrod lift?
