EGR and AIR with LTs
I am going to be installing Pacesetter race style LTs, do i need any kind of plates to block anything off if i already got the race style headers? Eventually i will get an LS6 intake, but before that, do i need anything at all to block off the EGR and AIR? I know that the fact that they are race style deletes the EGR provisions off of the headers... Thanks
I'm not sure if the headers are the same for a 99 vs an 01, but mine came with the AIR block off plates along with the O2 extensions. I don't know alot about the EGR, just that my car didn't have it. Your car will throw a code, but get it tuned out, no biggy. I got hooker lts, but a buddy of mine has some pacesetters on his 00 ss, and I believe they didn't even have a place for AIR hookups on the headers. Just pull the AIR system off. I know it probably wasn't, but I hope this is at least a little helpful.
You can remove both the AIR and EGR from the vehicle. You will have a hole in the top of the intake behind the TB that needs to be blocked. You can make a plug for it or GM makes a block off plate to put in place. They are like $15.99. Give us a call if you need one!
Jon
Jon
