knock passenger side help
Old 01-21-2009, 06:08 PM
reaperracer666's Avatar
Default knock passenger side help
i got a knock on passenger side after cam install i have messed with the rockers mutiple times still knocking and it incresses with rpm has new lifters cam timing chain no air no egr no evap lt headers new pushrods the correct length no metal shaving in oil any ideas?
Old 01-21-2009, 08:44 PM
SoxXpupPeT's Avatar
did you retighten your exhaust manifold ?
Old 01-21-2009, 08:48 PM
RamAir95TA's Avatar
There is a definite difference between a knock and a tap. Which one is it?
What do you mean you "messed with the rockers" multiple times? Did you set the valve lash properly? Sounds like a loose rocker to me.
Quick Reply: knock passenger side help
