Plugging hole in timing cover left by E-wp.
Old 01-22-2009, 06:17 PM
I8ASaleen's Avatar
Default Plugging hole in timing cover left by E-wp.
Alright the car is coming back together but before I can put the water pump on I need to know how everyone plugged the hole that's in the timing cover left by removing the waterpump drive. I bought a 50 cent 5/8 freeze plug and it was too small, I don't know it they have an 11/16 there or not. Anyone else run into this?
Old 01-22-2009, 06:32 PM
fergymoto's Avatar
Have it welded up.
Old 01-22-2009, 06:36 PM
I8ASaleen's Avatar
Welp not really an option atm b/c everything but the wp is back on the car...I wish I knew someone with welding capabilities or else I would've done it when I had it cleaned and painted.
Old 01-22-2009, 06:44 PM
James Montigny's Avatar
Old 01-22-2009, 07:37 PM
I8ASaleen's Avatar
What can I say, I don't know anyone that knows how to weld except for a guy at an exhaust shop.
Old 01-22-2009, 07:49 PM
FlamingChicken's Avatar
pretty sure the one i used was 11/16". just put silicon around it to keep it in place. remember i almost dropped the 5/8 inside the cover.
Old 01-22-2009, 07:51 PM
SpeedDensityZ's Avatar
Could you use a freeze plug?
Old 01-22-2009, 07:57 PM
I8ASaleen's Avatar
Ok I measured it and it looked like either a 5/8 or an 11/16, I'll try the 11/16.
Old 01-22-2009, 07:58 PM
SnakeOiler's Avatar
I used JBweld on a freeze plug. worked great.
Old 01-22-2009, 07:59 PM
hashtagBMW
Speed Density's Avatar
I have a half dollar welded on mine.
Old 01-22-2009, 08:11 PM
Moderator
BizZzatch350's Avatar
Freeze plug works well, I had mine welded close. Cost abut $40 though.
Old 01-22-2009, 08:26 PM
SprayedLT1's Avatar
I jb welded a quarter on mine. I have pics somewhere but won't be able to post them until tomorrow.
Old 01-22-2009, 08:58 PM
SLawson86's Avatar
drilled mine out and pressed a metric freeze plug in place
Old 01-22-2009, 10:52 PM
2XR95Z28's Avatar
I JB welded a plug my buddy made in mine, you can see the pics on my motor build thread, its gonna be tough to get a good seal on it if the cover is still on there though...
Old 01-22-2009, 10:56 PM
Wow, I didn't think JB would hold up with the heat and vibration.
Old 01-22-2009, 11:21 PM
2XR95Z28's Avatar
i've been told by multiple people they have had it for years and no problems one guy said he JB'd in a quarter and its been like that for 5 years.... If it looks like it's starting to crack at all i'll pull it and find somewhere to get it welded..
Old 01-22-2009, 11:24 PM
I8ASaleen's Avatar
Hmmm I might just gather up some JB weld and a quarter then. Gotta get the car done pretty much tomorrow or Sat so something is better than nothing.
Old 01-22-2009, 11:30 PM
Use a 50cent, it will last twice as long.
Or a silver dollar
Old 01-23-2009, 12:00 AM
LSWHO's Avatar
Originally Posted by James Montigny
Use a 50cent
I disagree, his career seemed to end pretty quick. Thank god.
Old 01-23-2009, 07:51 AM
GIZMO's Avatar
You can also use the old seal. Just cut a piece of thin sheet metal and use the seal to hold it in place. Otherwise, the half doller trick works well. I use "The Right Stuff" to hold it in place.
Quick Reply: Plugging hole in timing cover left by E-wp.
