defroster
defroster
When I put the defroster on there is a hissing noise coming from the dashboard, it only comes on if just the defroster is on, if i put it on the mode where heat goes to feet and defroster it doesnt do it. If i use regular heat it also doesnt do it..any one know why it would make a hissing noise
The control for the heat/air/defrost is controlled by vacuum. There is a multi hose fitting behind the dial. Pop off the trim and remove a couple screws and pull out the control. You may have a leak behind the control.
