Motor is out: How much $ to convert to low compression for turbo setup?
Old 01-24-2009, 08:25 PM
WizeAss's Avatar
Default Motor is out: How much $ to convert to low compression for turbo setup?
Just curious.... I have flat top pistons and approx 11.5:1 compression. How much extra would it cost to convert to another 408 piston that would be better for boost? Looking at going to approx 9.5:1 or 9.6:1 compression? I have very well ported L92 heads and an eagle 4.0 crank
Thanks in advance.
Old 01-24-2009, 11:01 PM
GueSS Who's Avatar
I think you need to wait and see what the rest of the stuff is going to cost before you worry about pistons. You might need a new crank and main caps with all the walking that bitch was doing.
Old 01-24-2009, 11:51 PM
ItsNotStock's Avatar
People have been using the stock crank up to 1,000 hp. And for his goals the stock main caps should be fine as long as he has aftermarket bolts/studs. How many miles do you have on your current setup? I remember you putting it together not too long ago. You might only be out the pistons/rings, hone, new cam, and some gaskets.
Old 01-26-2009, 09:14 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Keep in mind that to rebalance a previously balanced crank, takes a bit of skill. You just can not go slapping in malley where ever. In the long run it will be better to sell you current 408 shortblock and buy a new low compression shortblock.
Old 01-26-2009, 10:35 AM
Brad Hutchcraft's Avatar
or sell your heads and go with a bigger chamber.
Old 01-26-2009, 02:45 PM
Photochop's Avatar
Might look into selling your existing shortblock to fund the cost of a new more FI friendly one if thats the direction you're wanting to go? Might save on machine shop costs this way...
Quick Reply: Motor is out: How much $ to convert to low compression for turbo setup?
