Leaking Coolant... Help.
Car is leaking coolant. Checked the level and it was low. I filled it about 2 weeks ago... not it's almost empty.
What could be the problem??
Could the bleeder be not tight enough?
The car never leaked before.
I took it to a shop and they tried to do the 160 T-stat swap and they couldn't. Now the car has been leaking from the front driver's side.
Only thing on the drivers side is the upper radiator hose...or a crack in the radiator.
You'll have to fill it up and get the engine hot, operating temp, and look for leaks. Thats about all you can do.
couldn't change t-stat why ?? im no Mechanic and i can change a t-stat in a few min. anyways it could be a hose is leaking or could be your water pump
They said there was a fit issue. Whatever... I won't name names.
I'll have to check for leaks now.
Thanks for the response tho... Now I have an idea tho.
