Generation IV Internal Engine - L92 heads
Bad Chad
01-26-2009, 08:42 AM
I have a 99 Z-28 with a 6.0, 583 heads, Texas Speed Torquer V.3 Camshaft - 231/234 .643"/.598" 111 LSA, Fast 90/90 intake
I spun a rod bearing and now I having the short block built with forged internals so I figured I will up grade my heads.
I have been looking at the L92 heads because I was told they make really good power. My question is, do I have to change heads bolts, intakes, push rods etc.. I do know they need the off-set rockers for the exhaust valves.
Gen414
01-26-2009, 09:08 AM
One: Offset for intake, not exhaust
Two:Intake manifold is changed yes (rectangular Vs. cathedral)
Three: What head bolts do you have? Stock torque to yield? Yes, you do have to change them.
Four: Pushrods I am not sure on, however, I would think yes you would.
Bad Chad
01-26-2009, 10:02 AM
One: My bad, I knew it was one or the other... :bang:
Two: What intake do I need to use? L76?
Three: I have the ARP Head studs, I was not sure if I needed a different length stud
Four: I just bought push-rods when I had the 6.0 installed, I will check the length on them.
Gen414
01-26-2009, 03:45 PM
One: No problem
Two:Yes, the L76 is the right intake
Three:As long as you are not changing blocks (mid '05 and up use different bolts/studs) you will be fine then
Four:Anytime you change heads/rockers/cam it is in your best interest to check pushrod length as ANY small change in teh above parts can and will affect valvetrain geometry. If you are having the block decked/milled or heads resurfaced, same thing, pushrod length needs to be checked
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
