who sells lifter holding tool?
Hey, so I got a couple cam only sidejobs coming my way and I know that there is a tool that you slide in the lifter oil galley to hold the lifters up. Who sells them? Can I make one out of some steel?
Thanks alot
Thanks alot
LSX Mechanic
Go to Home Depot or Ace Hardware, and buy two 5/16 metal rods. Cut them to fit, and there's your lifter holding tool for about $10 total spent.
You'll need to round off the edges of the tip that go into the motor, especially on the pass. side. Helps them slide in easier.
Thanks man, I figured there was a Home Depot solution to this.
LS1Tech Premium Sponsor
Agreed! Damian's suggestion is the way to be!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
