Compression question?
Old 01-26-2009, 11:05 PM
peedeerooster's Avatar
Default Compression question?
I am building a 370, ie a LQ9 that is .030 over. I have noticed that most of the pistions that are 4.030 are built for 6.125 rods. I am reusing my LQ9, 6.098 rods and have 64cc heads. I was going to use flat top aftermarket pistons with valve reliefs. Does anyone know how much compression I will lose by running the 6.098 rods versus the aftermarket 6.125 rods, since the compression height will not be as high with the shorter stock rods? Thanks
Old 01-26-2009, 11:10 PM
Tom@SpeedInc's Avatar
compression height isn't an issue, the pistons setup either way at hypothetically 0 deck.
I can assume your using Mahle pistons?
0 deck with 6.0 MLS gaskets i'm showing 10.87:1
Old 01-26-2009, 11:16 PM
I haven't bought any yet. I was just looking around at them doing a little research to see what my options are. Since the motor is going in a truck and is naturally aspirated, I am trying to not give up any SCR.
Old 01-27-2009, 06:35 AM
405HP_Z06's Avatar
Are you saying you want to use a 6.098 rod with a piston designed for a 6.125 rod?
Old 01-27-2009, 08:33 AM
The pistons are speced for both.
Old 01-27-2009, 09:28 PM
405HP_Z06's Avatar
If the only difference is compression height, you won't see a change in compression ratio assuming you use the correct rod for the correct piston. Your rod/stroke ratio changes with the rod change, but not compression.
