Solid roller 383 engine dyno numbers
Well my solid roller 383 was finally wrapped up and dynoed today on the engine dyno. The combo is an EB ported AFR 220's, Accel pro ram intake, 259 267 108 lsa cam .57x lift, T&D rockers with 12.15-1 compression. The car is set up for fuel injection but the shop does not have the ability to use fuel injection on the combo so I borrowed a 750 carb to put on the combo for the dyno and a standard mechanical advance distributor. We only made one pull to 7200 rpms with a very conservative tune and the combo made 520hp@6500rpms and 480 ft/lbs@5000rpms. The egine builder says that the 750 is way undersized and he has no doubt a 1050cfm dominator would net another 60-70hp as he said the power flattened out at 6500rpms. The engine made 472ft lbs at 4000 rpms so it is a torquey engine. The engine builder said there was no use in him dialing it in (more $$) as I am fuel injecting it anyway but I wanted to have it dynoed and valves adjusted etc so that is the only reason I dynoed it this way. The combo was also dynoed without the crankcase vacuum pump which should also net me another ~10-15hp. All in all I am very happy with the numbers and expect somewhere around 600-620 crank horsepower once the engine has the fuel injection, vacuum pump and proper dyno time/ break in. I am shooting for mid to high 10's NA and low 9's on the bottle.
Matt
Matt
I will have the weight down to ~3500 but my car is still a street car and I weigh 235 so it will be difficult to get it light and still be a "street car". If I can run the numbers you run N/A with the 3.70's and nitrous verter I would be really happy.
The engine is already "broken" in. I was refering to making a little more power once I get a few passes on the combo just due to ring seal, etc from running it.
Yeah, this was Dirk's old motor. I only kept the crank, block, heads, and intake. Everything else was upgraded and changed out. It needed some machine work and cleaning from sitting around and when I pulled it apart to check the parts I found they were under rated for the type of combo I wanted.
yup great #'s...... especially with a 750 cfm on there.... what are you using for a topper on that pro ram when you're FI???? Accufab TB? Elbow with a 90mm TB????
be sure to read the elbow vs accufab 4500/4150 tb thread i believe in the drag racing tech section b4 you purchase.... some ppl getting upwards of 50-60 hp from going to a 4150 style TB.....
again nice #'s.... better hurry up cause I intend on having the record soon...
Thanks for the info. Right now, I have a 4150 style throttle body that was supplied with the pro ram kit from accel. It is supposed to flow ~1200cfm.
Sweet Deal Matt. Glad to see that ol hunk of Iron is gonna get some use.Really nice numbers,and yeah it should really pick up when you get everything on it.
Damn shame i never got it in mine.
I'm new to Lt1's and saw that you was running quite a bit of compression... and I know the design of the Lt1's let you run more compression, but what would you guys consider safe on 93 octane pump gas?
Matt
Matt
