oil pressure???
Old 02-01-2009, 01:44 AM
01z
01z's Avatar
Default oil pressure???
i just did an oil change and whenever the car is idlling (sub 1000 rpm) the pressure is below the halfway marker a little. whenever im cruising its just above the half, and beyond when i give it gas.
is this normal to be that low while idling?? before i changed it it was regularly at the 3/4 mark. i switched to mobile 1 10w30. also when i drained it it barely had 4 quarts in it!
i dont see how it could have had better oil pressure w/ less oil in it
Old 02-01-2009, 02:15 AM
01z
01z's Avatar
damnit posted in the wrong section, im referring to my 99 ta ls1. dunno why i posted in the gen 4 section
Old 02-01-2009, 07:33 AM
davidws6's Avatar
Default Oil Press
Other oil prior to the change thicker ?
Mobil 1 10/30 is pretty thin, but a good oil..
Old 02-01-2009, 08:17 AM
01z
01z's Avatar
i dunno what oil it was, just bought the car
Old 02-01-2009, 08:54 AM
Texas 02 Z28's Avatar
My oil pressure used to be right at the middle mark at idle. Bolt on 2002 Z28, Mobil 1 5w30.
That sucks the previous owner ran so low on oil. I'd check your oil level somewhat often to make sure you don't have a leak somewhere.
Quick Reply: oil pressure???
