idle keeps relearning
O.K. after adjusting the blade several months ago to cure a bobbing idle issue now all the sudden out of nowhere it'll do the " cruise control idle" thing especially after pushing in the clutch. I did the idle relearn and it returned to normal for a few days then started over again with the high idle( ONCE at a complete stop it returns to designated idle. You snap the throttle and it goes up to 2000 or so and takes a few seconds to return. I have done the idle relearn process many times and it DOES work, but seems to return within days or sometimes hours? I have also noticed ( since paying attention to everything now) that my SES light doesn't always come on when the key is turned to run. ( VCM communication problem?) Seems as if 9 out of 10 times it comes on. Car seems to be running good other than the JOHN FORCE IDLE!!
