Window out. Need help
Okay so I had the t-tops out and the windows down. I went to roll the drivers side window up and it got up about 6 or 7 inches and then I heard a pop and then nothing. I can pull the window up and down manually and it will stay unless pressure is applied either way but no matter what I do or how the window is positioned I cant even get the window motor to even make a sound.
So is the window misaligned or the motor broken and what kind of bill am I facing to get it fixed?
On another not I cant pull the window pulled up all the way only about 2 inches from the top then it stops.
