are roller rockers noisier then stock rockers?
Old 02-07-2009, 06:00 PM
slagger's Avatar
Default are roller rockers noisier then stock rockers?
just wondering because I was doing alittle work on my daughters truck and its a stock chevy 350 1993 and its quite no lifter or rocker noise but on my motor its noisier not a tap sound just the valve train noise but i'm not stock but is it norm to have noise on top?
the noise isn't there at idle just when you rev it up
thanks.
oh my motor has 4000 miles and I adjusted the valves 2 weeks ago and I did it 1 turn past preload.
5-30 oil
Old 02-07-2009, 06:11 PM
SprayedLT1's Avatar
Yes, they are considerably noisier than stockers.
Old 02-07-2009, 06:13 PM
Formula350's Avatar
Yep, quite a bit noisier. AND the injectors will really add to the noise, more-so if you have aftermarket injectors. Just having the 8 injectors will make a noticeable addition to 'ticking'.
Old 02-07-2009, 06:40 PM
slagger's Avatar
yep I have 32 lb injector, it sounds good and healthy but you hear the valve train.
Old 02-07-2009, 08:09 PM
slagger's Avatar
heres a clip.
you can even hear the cai
Old 02-07-2009, 09:01 PM
ss.slp.ls1's Avatar
thanks.
5-30 oil
You mean you added 1 turn past zero lash (adding preload).
Normally, for stock rockers, 1/2 to 3/4 turn is adequate.
Old 02-07-2009, 09:43 PM
slagger's Avatar
yes correct 1 turn after zero lash
I fig sense everything was new and breaking in that 1 turn would be ok motor has 4000 miles
Old 02-07-2009, 11:22 PM
ss.slp.ls1's Avatar
The lifters determine the amount of preload, and it shouldn't matter how many miles are on the engine. I always use 1/2 turn past zero lash. I have full roller rockers and they are a little bit noisier than stock. As long as it's not really loud or hitting the valve covers, you should be good.
Old 02-08-2009, 09:00 AM
97pontta's Avatar
Those roller rockers sound normal, my crane 1.6's are a little noiser. I found my car to run the best with only a 1/4 turn past zero lash. I tried 1 full turn, 3/4, 1/2, 1/4 and 1/8. Every setup is different but 1/4 is where I left mine.
Old 02-08-2009, 11:01 AM
krill's Avatar
Sounds good, quieter then my promags The idle sounds similar to my lil cam!
Old 02-08-2009, 05:06 PM
leadfoot4's Avatar
True!
The GM shop manual calls for 1 full turn, but that's on a stock engine with stock lifters. CompCams, on the other hand, calls for 1/8 turn on their 875R lifters, and they are ADAMANT about it.
Old 02-08-2009, 11:13 PM
Elliott's94Z's Avatar
I'm really not sure if they are noisier, I can't hear them over my cam
Old 02-09-2009, 09:39 PM
slagger's Avatar
I have the trick flow lifters & PR .080 harden 1 piece
