LS1 in 72 TA
I already have the motor in with headers.
I have a 79 TA I will be doing some thing like this to. What I would do is smooth the fire wall use all the new parts that come with the new motor.Check on year one web site look at the bandit set up http://www.yearone.com/serverfiles/f...2.asp?cat=4,or go to,
http://www.detroitspeed.com/
Hope this help any.. let us know what you do thanks..
If you need good gas SS tank
http://www.rickstanks.com/musclecartanks.htm
I have a 78 ta with factory a/c and used the original system. I used a sanden compressor wit a Kwik performance bracket.I used a replacement acumulator (dryer)that was for r134.
Installed a new type pressure switch and a variable orfice tube.I used over the evaporator core (had it tested for leaks). I bought a New condenser and made my own lines.Pretty much bought everything on E bay and also used www.nostalgicairparts.com.
Did you use your factory gauges by chance?
