shaft mount rockers?
Old 02-14-2009, 01:40 PM
z28rob18's Avatar
Default shaft mount rockers?
will a shaft mount rocker for a traditional sbc head work on the lt1 head? the valves arent spaced different are they?
Old 02-14-2009, 01:51 PM
Formula350's Avatar
LT1 is a SBC with the exception of a few technical differences. 90% of GEN I items will work on the GEN II (LT1) either directly or with some work. So whatever work has to be done to the SBC for shaft mount, will be the same for the LT1s. I think it'd be cool to run them My 64 Ford Jeep's engine has them, non-roller tip of course though.
Old 02-14-2009, 03:46 PM
z28rob18's Avatar
alright. bout to get a deal on a set for my build. the sprint car i work on is bein rebuild and the guy is sellin a set
Old 02-14-2009, 06:48 PM
speed_demon24's Avatar
The valve spacing is slightly different than SBC's which is why people run into valvetrain geometry issues with sbc guide plates. I'm not sure if this is relevant with shaft mount rockers, but I would check with someone who has experience with LT1 valvetrains before spending the money on shaft mounts.
Old 02-14-2009, 07:58 PM
FlamingChicken's Avatar
when i checked with byunspeed about what jesel shafts would work the part number for the lt1 was the same as for a gen 1. i know a couple guys on here are running shafts so maybe the will chime in.
Old 02-14-2009, 09:55 PM
z28rob18's Avatar
the guy that owns the sprint car is checking into it cause hes not sure if the heads he has are different or not
Old 02-14-2009, 10:35 PM
Formula350's Avatar
I was unaware of their difference, since RRs aren't specifically designed for LT1s. After all, the people who run NSA RR's are using just that, SBC rockers. And I was under the impression you fix geometry by changing pushrod length. Hell, you can even use LS1 rockers, as people have proven, but there is a more prominent geometry change and pushrods are almost a must if you want true 1.7
Quick Reply: shaft mount rockers?
