Injectors
Old 02-17-2009, 11:55 AM
domestic disturbance's Avatar
Default Injectors
Mods are in Signature... Question is should i put a set off F1SE-E5A injectors in before tune???
thanks alot!
Old 02-17-2009, 12:18 PM
nemss1's Avatar
if u are planning on installing the injectors eventually and plan on a tune, then yes. install the injectors first before u get the tune
Old 02-17-2009, 12:42 PM
ss.slp.ls1's Avatar
I would use an injector calculator to determine what injectors your set-up needs. And yes, install them before the tune.
Old 02-17-2009, 01:31 PM
massls1guy's Avatar
Don't mean to split hairs - I brought mine with me to the tuner and he put them on for me and did the tune with the new injectors. I don't think your car will run well if you install them and drive the car without changing the tune to work with them.
Old 02-17-2009, 01:36 PM
ss.slp.ls1's Avatar
That's what I meant.
Old 02-17-2009, 03:47 PM
so probably just take the injectors with me when taking the car to get it tuned....
thats probably what im going to do...
