93 t1 tb bypass?
93 t1 tb bypass?
i was bored and going to do the tb bypass on my car. i found a digram on shbox but its for a 95 lt1 and it looks slightly different. i was wondering if anyone new exactly how to do it and if theres any differences?
93s don't need anything but 2 hose clamps and a double sided barbed fitting. The stock hose that runs to them is long enough to connect to each other AND tie off on the core support! I think the hose ID is 5/16, as mentioned.
That sensor is the IAC (Idle Air Control). And it has to do with idling, so yes airflow.
You can take that whole housing off and cut the coolant passages off if you want. Guy I bought my BBK from did that (with a band saw I presume) and left just the IAC Wish I had thought of that lol
thats wut i figured. i was wondering because the sensor was so old it got kinda cracked up when i had to remove it and when i got everything done my car would only start if u gave it gas and stayed running if u revved it up a lil. my fuel pumps went bad recently tho and i figured that it may have totally crapped out or do think that sensor could cause this?
It's only like $8 I think. And Shbox is right, it's not a sensor perse, but a valve. It does know(sense) it's position though and feeds that back to the computer
