Broken valve seal spring...
I found a broken valve seal spring or the little band that goes around the tip of the valve seal while changing my oil today. Do I need to get another one? Is it safe to drive the car without it?
Thanks!
Thanks!
LS1Tech Premium Sponsor
Replace it...they're cheap!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Almost looks like a chewed up lock....but I'd think you'd know for sure if one was missing!!
__________________
