WHat am I missing in this Cylinder head?
Old 02-19-2009, 05:11 PM
multmigs's Avatar
Default WHat am I missing in this Cylinder head?
Is there something that should screw into this hole my finger is pointing at in this stock head? I just got them back from LE and there are bolts for the brackets on both sides that go into the other 2 bolts but nothing into this that I can see from what I have assembled so far? same thing on both sides... No its not the coolant tube on the back, been there done that already...
Old 02-19-2009, 05:17 PM
ss.slp.ls1's Avatar
No, that is for the accessory bracket. That bolt hole should not go all the way into the head.
http://shbox.com/1/accy_brkt.jpg
EDIT: After looking at the above picture, nothing goes there at all. The Accessory bracket uses the upper two bolt holes, not that one.
Old 02-19-2009, 06:09 PM
multmigs's Avatar
[QUOTE
EDIT: After looking at the above picture, nothing goes there at all. The Accessory bracket uses the upper two bolt holes, not that one.[/QUOTE]
Yeah that's what I just asked about, so nothing goes in this hole at all, no plug needed etc?
Old 02-19-2009, 06:12 PM
Formula350's Avatar
Nope, nothing.
And... rubber gloves... RRRRREALY? lol
Old 02-19-2009, 06:42 PM
FASTFATBOY's Avatar
I think there are 3 acc bolts in the top of the bracket arent there? There is one that hard to see in the bracket.
Old 02-19-2009, 06:56 PM
Raven97's Avatar
How are you supposed to get grease under your nails if you are wearing gloves???
Old 02-19-2009, 07:03 PM
ss.slp.ls1's Avatar
Originally Posted by Formula350
Nope, nothing.
Yeah, nothing. Like I said above, that hole doesn't go all the way through the cylinder head wall.
