Injector Question
When I spoke to Lloyd Elliot about my cam swap he said that 30 SVO's are typically good upto 425 RWHP. But as most will tell you there is now way to tell unless you scan it and see what the Inj Duty Cycle are at and if you are peaking past 95+%. Might want to look at 37# if you are set on getting new injectors.
Many 383s are fine on 30lbs injectors IF the fuel system is up to snuff. I would not assume they are too small just yet.
MANY high rpm power losses are caused by improper or worn out springs but everyone wants to change everything else first.
When folks reccommend an injector ask WHY, the answers will usually center around MARKETING though the person doing the recommending wont realize that is what swayed them.
