Need help finding a stroker kit
Have a LS2 Sleeved block bored to 4.125. I have L92 heads with 70cc chambers. I want as close to 11.1 compression ratio. Are there any stoker kits out there? Any suggestions?
Thanks
Thanks
LS1TECH Sponsor
LME can offer you a rotating assembly to make a 427" 11.0:1 compression with the following parts:
-Callies Compstar 4340 4.0" stroke crankshaft
-Callies 6.125" H beam rods w/ ARP 2000 7/16" bolts
-Wiseco 4.125" bore -8cc reverse dome nitrous pistons w/ L92 valve pockets
-Total Seal Ductil Moly rings
-Clevite H series main & rod bearings
-Crankshaft balanced to 1/4 oz. in.
-Rod bearing clearances checked & adjusted for application
Price is 2449 shipped.
Feel free to ask any questions about the set up.
Thanks,
Bryan
LME
713-849-4505
Thanks,
Bryan
LME
713-849-4505
