Stereo & Electronics - sub not working
2002redhawk
02-25-2009, 07:15 PM
Well i know the subs work. I have everything hooked up correctly except the rc cables. Heres the problem i have a jensen uv8 flip out. It only have one subwoofer outlet port. I've tried hooking that one port up and just running one sub and it didnt work. I've also tired hooking up my subs off the rear audio l and r outputs and that didnt work. I dont know what it could be. Any ideas?
4THGENCAMAROFAN
02-25-2009, 07:21 PM
Well i know the subs work. I have everything hooked up correctly except the rc cables. Heres the problem i have a jensen uv8 flip out. It only have one subwoofer outlet port. I've tried hooking that one port up and just running one sub and it didnt work. I've also tired hooking up my subs off the rear audio l and r outputs and that didnt work. I dont know what it could be. Any ideas?Take a voltometer and make sure you have power at the amp's positive terminal, make sure you have a good ground, make sur your remote turn on wire is hooked up too. If you test the positive terminal and you don't have power check the battery terminal and check you in-line fuse or ANL fuse, which ever you have. Hope this help...good luck.
95TAJade
02-28-2009, 05:25 PM
4thgen's got it right on the nose!
4THGENCAMAROFAN
03-01-2009, 04:16 PM
4thgen's got it right on the nose!yay!!!!!!!!!!
layitlow
03-01-2009, 09:13 PM
i had the same flip out and i used a splitter on the sub output
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
