Quick dyno/afr question
Old 10-15-2003, 09:26 AM
Mike00FRC's Avatar
Default Quick dyno/afr question
If you run a tune on the street and see a flat 12.6:1 afr (LM-1) and then strap it on a Dynojet, will the afr on the dyno be leaner or richer?
I know that the load will be higher on the street, so I would think that the dyno would be richer, but I'm not sure.
Any opinions?
Old 10-15-2003, 11:09 AM
TILEMAN's Avatar
Default Re: Quick dyno/afr question
I say richer.
Old 10-15-2003, 12:22 PM
red ws6 99's Avatar
It should be richer because the dynojet has a lot less load than the street. Now if it was eddy current dyno (mustang, etc) then it should be fairly close.
Gary
Old 10-15-2003, 03:35 PM
Mike00FRC's Avatar
Thanks.
Now, is there any way to estimate the afr increase if tuning is done on a dyno, and then driving it on the street. Say, tuning it to 12.4 on a Dynojet248 and then running it at WOT on the street/track.
Old 10-15-2003, 06:27 PM
MYTURBOT/A's Avatar
they say that you`ll be a half a point leaner on the street so if your 12.5 on the dyno youd be 13.0 on the street. but thats just what i`ve heard. but it realy depends on how the dynos set up the calibration can be made to account for the extra load on the street
