Lt1 in my 94'
Lt1 in my 94'
So i have decided to swap my 3.4L v6 for a LT1. I am going to buy a used motor and swap it in. But, what i need to know is what additional parts will i need for the swap? wiring harness? motor mounts? i need to know everything! thanks
-Adam-
-Adam-
Easiest thing to do is to find a cheap or wrecked donor car and swap parts as you need them. IIRC, you need at least the LT1 radiator, cradle, transmission and a host of other minor parts. Consider the fuel system as well - not sure if the V6 fuel pump will be able to keep the LT1 supplied with ample fuel pressure.
There's many threads on this subject if you do a search, the majority will side with what we've said on finding a donor car due to all the stuff you require.
GL though!
