LOUD whistle noise under accel, total power loss
Old 03-04-2009, 01:25 PM
bastien's Avatar
Default LOUD whistle noise under accel, total power loss
Hey guys,
I was on the highway today, going about 60mph, when it all happened. I had to make an emergency stop...
Every time I would give it gas, it would make a terribly loud whistle/hissing noise that would get louder as I gave it more gas (the rpm wouldn't move, no power at all in 4th, stayed about 800-900 rpm). It did it in 5th and 4th gear. The noise sounded like it was coming from the engine bay... I pulled over and it was still doing it in neutral. I let it sit for about 10min and I was able to drive home after that, no problems at all, no noise, power was back to normal. Now I am unable to reproduce the problems which makes it hard to diagnose.
help please
Old 03-04-2009, 01:37 PM
Rapter34's Avatar
That kind of sounds like a vacuum leak but since you say it went away on its own I really don't know what it could be.
Old 03-04-2009, 01:45 PM
bastien's Avatar
that's what I thought too... anyways thanks for your input
anybody else?
Old 03-04-2009, 01:50 PM
Now you have my attention
GTOSE's Avatar
Sounds like a vacuum leak to me as well. Did it throw any codes?
Old 03-04-2009, 01:54 PM
bastien's Avatar
no codes at all. I scanned it while driving, and stopped, then again at my house.
Old 03-04-2009, 01:59 PM
bastien's Avatar
would a vacuum leak have all these effects? I mean I really had NO power.. I gunned it in 4 th and I stood still...
Old 03-04-2009, 04:43 PM
bastien's Avatar
bump, anybody? this is my daily
Old 03-05-2009, 11:23 AM
Greg Fell's Avatar
you sure all the duct tubing/maf/tb is all good?
Old 03-05-2009, 01:01 PM
bastien's Avatar
i will check that next, thank you
Old 03-05-2009, 05:25 PM
382ssz28's Avatar
We had a customer that had a bad mount. It rocked the motor just enough to pull away from the inlet of the TB, causing a very similar problem. My point is, check the bellows area as the mass air meter was probably going nuts until the leak was sealed. I saw a guy at the track that had a small backfire and popped the hose off at the pass side of the intake and did not cause the motor to act up. Just had an erratic idle and whistled. Hope this helps.
PS, can she pose for my car?
Old 03-05-2009, 06:22 PM
bastien's Avatar
I think I found what was wrong...
The butterfly of my electric cutout was missing and got aspirated in my exhaust... took my exhaust apart and found the little bugger all bent... I am assuming it was blocking air flow thus decreasing power...
go figure.
Old 03-05-2009, 06:23 PM
bastien's Avatar
thanks, i will look into that, if the whole cutout thing wasn't it.
ask Whistler, that's his wife. He posts on here.
Quick Reply: LOUD whistle noise under accel, total power loss
