Size and thread count of studs on truck manifolds?
Old 03-05-2009, 07:52 PM
Restricted User
98Z28CobraKiller's Avatar
Default Size and thread count of studs on truck manifolds?
Does anyone know the size and thread count on the studs that come welded to the truck manifolds? I dont want to have to take them off and bring them to the hardware store.
Also, what hardware are you guys using to mount your T4 turbos to their flanges?
Old 03-06-2009, 05:24 AM
Restricted User
Nobody knows?
Old 03-06-2009, 06:10 AM
HUNTER02SS's Avatar
The studs on the manifolds come out. They shouldn't be welded I don't think.
As far as hardware, I just used some grade 8 bolts and nuts to mount the turbo to the flange.
Old 03-06-2009, 08:21 AM
I'm Mike Hutto
Rapin'Ya's Avatar
10mm X1.50
Old 03-07-2009, 06:54 AM
Restricted User
Thanks
Old 03-07-2009, 07:04 AM
Restricted User
I meant configuration and size. For instance, my T4 flange on the merge is threaded. I got some M12 bolts to match up with the threads. When I looked at the flange on the turbo, there is no way to get a long M12 into the hole due the exhuast housing being in the way. This makes me think that perhaps I should tap the back bolt holes and stud them on the turbo. Then have the hot-side flange have the other 2 studs. Get the back 2 from the top and the front 2 from the bottom. sound good?
Old 03-07-2009, 11:00 AM
TurboZ28408's Avatar
10X1.5 or 3/8-16 work too very similar threads **
Quick Reply: Size and thread count of studs on truck manifolds?
