SLP LS6 Intake Manifold ?
I recently purchased an SLP LS6 Intake manifold off of a friend. His car was a '98 Camaro and mine's a '00 WS6. None of the ribs on the bottom of the intake are ground down, which I thought was odd considering he has a '98. I asked him if he also had the LS6 coolant lines and he said no. So, my question is, is the SLP intake designed so that you can still use the LS1 coolant lines without having to grind or chip away at the ribs?
Thanks...
Thanks...
