need help
Old 03-07-2009, 08:29 PM
crazygn's Avatar
Default need help
i run a set of 241 heads and these coils and brackets, i think there truck style. I tried to put my plug wires on today and there to short. Also my fuel rail feed line hits the coil so it cant be right. Any one know what gives here , wrong bracket or something
Old 03-07-2009, 08:44 PM
xpndbl3's Avatar
slowly bend the fuel line up out of the way, just be gentle.
those are truck coils so you would need to run truck spark plug wires. While you're swapping them out might as well just get some nice msd wires.
Old 03-07-2009, 08:45 PM
oange ss's Avatar
truck coils sit up higher off the valve cover for more clearance around the coils themselves, need truck wires or LS2 wires
Old 03-07-2009, 08:51 PM
crazygn's Avatar
really , i just spent 70.00 on wires and iam not sure if i can return these, sucks. thanks for the help guys
Old 03-09-2009, 10:01 AM
topher455's Avatar
I used the car wires and truck packs. Just elongate the mounting holes and bend the coils up at the top to angle the wire end down. Or just put some washers onder the top side of the coils. You cant tell when they are done.
Quick Reply: need help
